Yup, won't work. I looked into that and ending up getting the a-pillar pod.
Will this work with a 6 speed?View attachment 14328
It says for Automatic in the description. Just did not know If it would get in the way of the stick.
Offroad Engineering makes one that will work with a manual though. Moby is running one.
I thought I read Eddie used the Daystar panel to put the off road engineering panel on.:thinking:
is that a Daystar panel on your rig?The reason why you can't use the Daystar panel with a 6-speed is because the rubber boot hits the large switches and activates them. With the Off Road Engineering switches, this isn't a problem as the panel is thin and the switches are small. I'm not sure how things work on a 2011-up as the center stack is designed differently, the shifter lever is bent and now comes with a leather boot.
