Strodinator
I finally got around to changing the oil in my rear differential today and took some pictures so I figured I'd write it up for those of you that haven't done one yet and I don't see a Dana 34 specific one. I started by soaking every bolt on the diff cover with PB Blaster for about an hour before I started, which turned out to be beneficial because the PO had put gasket maker on each of the bolts to help seal. These were very easy to get off so I lucked out.
