I had read how hard they can be to get inserted into the tubes so I threw mine in my freezer for a couple days and they pushed right in by hand. Maybe I just got lucky, not sure
Shafts are going to be pulled because of the sleeve installation.
I don't NEED to get into the diff right now, but one inner seal is already blown.
If i take the ring and pinion out to replace the bad one, might as well replace them both.
Plus when i am cleaning out the axle tubes i won't be pushing everything down into the tube to the inner seal, i will push everything into my empty differential which is an easier clean up.
You just have to take out the ring gear and carrier not the pinion. And it will be a lot easier to replace the seals before you put the sleeves in because you need to hammer the seal out and with a sleeve it will be harder
