FenderBender
Friday night my 2009 Rubicon felt sluggish, was running really rough, and had a persistent check engine light flashing on the 5 mile drive home. Using the built-in code display, the code was p0302 indicating a cylinder 2 misfire.
I knew that my spark plugs were old (95k miles), so I replaced all plugs and wires yesterday. Still basically the same symptoms.
I haven't replaced the coil pack. I figured I'll do this next. Should I just get a Mopar replacement? Any advantage to other "performance" variants, or is that asking for trouble/waste of money?
I will also add some Red HEET in case my fuel is bad and it should also act as an injector cleaner.
Besides that, what else should I be looking at?
Thanks for and advice.
