Custom cage
Md_rubi
I finally got my cage built last summer and here it is.
DOM tubing being delivered for cage build. All USA made DOM
ImageUploadedByWAYALIFE1360040179.917669.jpgImageUploadedByWAYALIFE1360040200.070676.jpgImageUploadedByWAYALIFE1360040217.236431.jpg
Stripped and ready to start the cage
ImageUploadedByWAYALIFE1360040258.976022.jpgImageUploadedByWAYALIFE1360040285.950076.jpgImageUploadedByWAYALIFE1360040321.331032.jpgImageUploadedByWAYALIFE1360040361.921066.jpg
Jig for tube alignment since I will be reusing the factory tops.
ImageUploadedByWAYALIFE1360040434.725648.jpgImageUploadedByWAYALIFE1360040450.526767.jpgImageUploadedByWAYALIFE1360040475.052694.jpg
Factory tubing removed. I was surprised how heavy the jk tubes are, least lot stronger then, CJs and TJs
ImageUploadedByWAYALIFE1360040573.496616.jpgImageUploadedByWAYALIFE1360040613.599914.jpgImageUploadedByWAYALIFE1360040647.815312.jpgImageUploadedByWAYALIFE1360040684.317434.jpg
A,B,C,D plate welded to tub. I don't have pics of the underside of the tub.
ImageUploadedByWAYALIFE1360040844.741459.jpgImageUploadedByWAYALIFE1360040867.798566.jpgImageUploadedByWAYALIFE1360040908.708911.jpgImageUploadedByWAYALIFE1360040934.830252.jpgImageUploadedByWAYALIFE1360040968.752649.jpg
More to come.
ImageUploadedByWAYALIFE1360041469.136489.jpgD pillar. One tube goes straight through behind the tail light and the other one is sandwiched between plates and welded to frame.
ImageUploadedByWAYALIFE1360042116.916722.jpgImageUploadedByWAYALIFE1360042132.387660.jpgImageUploadedByWAYALIFE1360042039.921795.jpgImageUploadedByWAYALIFE1360041590.031052.jpgSome of the gussets double as tie downs
ImageUploadedByWAYALIFE1360041632.344948.jpg. View from top
ImageUploadedByWAYALIFE1360041661.042146.jpg. One of the welds to frame. All downward tubing from A-D are welded to frame
ImageUploadedByWAYALIFE1360041761.487427.jpg. Windshield mount point
ImageUploadedByWAYALIFE1360041795.334417.jpg. Rear seat mount and cross bar for hardness and tire mount.
ImageUploadedByWAYALIFE1360041968.699757.jpgImageUploadedByWAYALIFE1360041928.818186.jpg. View from rear
ImageUploadedByWAYALIFE1360042156.428489.jpgImageUploadedByWAYALIFE1360042203.708386.jpgImageUploadedByWAYALIFE1360042220.742738.jpgImageUploadedByWAYALIFE1360042235.187594.jpgImageUploadedByWAYALIFE1360042254.700830.jpgImageUploadedByWAYALIFE1360042284.621765.jpgImageUploadedByWAYALIFE1360042296.383401.jpgImageUploadedByWAYALIFE1360042319.253590.jpg
very impressive ! Did you duplicate all the tubes ? Im in for the extra !!!:crazyeyes: Def would pay good money to have one built like that :clap2: :thumb:
ImageUploadedByWAYALIFE1360042373.743132.jpg. Enough room for a custom rear center console to match my tuff front. It will house my sub, power outlet, inverter, and couple cup holders
ImageUploadedByWAYALIFE1360042458.582583.jpg. This is how my spare will look.
ImageUploadedByWAYALIFE1360042531.503989.jpg. This is the removable spare mount.
ImageUploadedByWAYALIFE1360042585.070744.jpg. This will be the location for custom sound bar
ImageUploadedByWAYALIFE1360042635.785371.jpg. I'm thinking maybe this could be another location for speakers?
Thanks. I've been wheeling for many yrs and I've seen what happens with poor cage design or lack of. This should protect passengers for may of the toughest trails but it's not done yet. Once my engine swap is done I'm looking at caging in the engine and possible incorporating the shock towers.
Yes all but the A pillar. I gave the fabricator my requirements but left the design up to him. He's probably considered one of the best fabricators in the DC metro area and has built many rigs for KOH.
Thats SICK!!!!!!!!!!!!!
Where are you located in MD?
Did you roll your rear Trail mod flares? They look kinda rolled?
