Nataqua
Some of you know that a few days before Christmas my Jeep that was parked in front of my house at 2am was plowed into by an intoxicated asshat. I received the estimate yesterday and have a few questions for you all. Plus, if you are a Reno local, what's your opinion of Steve's Collision Center? I tried to get it into Coachcraft, but they are booked weeks out. I haven't yet committed to any certain repair shop. There is some visible damage to the frame, but the Jeep still needs to be put up on a rack to check the frame, that should happen tomorrow. The estimate is currently at about $5400.00
One question I have is about the axle ratio. I believe my Jeep had the 3.73 axle that came with the Max tow package, but I'm not sure how to prove that, should I need to. I mentioned it to the adjuster over the phone when he called me with the verbal estimate and I can see that he a already had 3.21 on the digital copy. I'll see if I have to push more for this or not. And, if I succeed, how can I tell what has actually been installed when the work is completed?
Second question is about new aftermarket parts. They've quoted O'Reilly upper and lower control arms...is there a difference in quality vs OEM?
Same question about Flares from Autonation, will they match and wear the same as the rest of my Jeep?
The third question is about the tire. They've quoted a used replacement wheel and intend to use the old tire and see if it holds air. Do you think the integrity of this tire would be compromised? If it does indeed get replaced, is the few thousand miles of wear differential of the remaining tires an issue?
Thank you so much for your help, I really don't have knowledgeable people in real life that I can go to with these questions.
