Clutch
If you were moving from stock to 37s or moving from stock to 40s, what the cost difference?
I'll starting the bid at $13.5k, from a stock jeep, I would think it would cost $13.5k MORE to run a 40" tire compared to the cost it takes to run a 37" tire.
I dunno. I hear guys put 40s on Dana 30s all the time.I'll starting the bid at $13.5k, from a stock jeep, I would think it would cost $13.5k MORE to run a 40" tire compared to the cost it takes to run a 37" tire.
Wow, are we taking the difference between the axle set needed and cost of tires? What else would be different. I was assuming you'd need the 44/60 for 37s and 60/FF60 for 40s... or are you assuming basic D44 axle reinforcement (gussets/axle shafts)?
Pretty good estimate, the cost delta mostly stems from the axles.
Suspension setups can be the same on 40's or 37's.
You guys in the US are lucky lol Those some axle packages are close to 20k with our shit dollar :crazyeyes:
Edit: comment was geared towards Dwiggles comment.
You don't NEED the PR60 rear for 37's. I would say a PR44 is a need though. I demo'd my braced housing super quick.
Rear hasn't taken much damage beside the flanges.
Are you thinking reinforced stock axle for 37 and all new axles for 40s!
You'll need to take steering upgrades into account as well, especially for 40's. XD box or hydro setup.
Ok, I see what your saying. Seems like if you buy the PR44 front housing, your still looking 8k, housing ~2500, rehearing ~2000, big brake front and rear ~1000, axle shafts front and rear ~1500, and ball joints ~500.
^^^^^ Above? :yup: :crazyeyes: :idontknow:
Depends how bling bling you wanna go. Assuming suspension is done and doesn't count and will work with both setups, could be up to 35k difference.
Sent from my SM-G955U using WAYALIFE mobile app
35k more? I don't know how it could be that much, unless you think a LS is needed.
