Hey guys taking odd teraflex fixed and adding adjustable to fix caster issue. Does this look right. Bend to the inside.
Or bend facing down??? Never had adjustable on both ends
I think those bends are correct. Turn the tires and check. Also, I run the core arms with zerks down and went with low profile ones. No issues so far but I've come close to hitting them.
The only reason the fronts are down is because I would never be able to grease them. Wouldn’t be able to fit grease tube end on them. It was sitting to fare back in the perch on the axle.
Where did you get those Doug?
So I decided to face the bends down. It just appears to look straighter however when I turn the steering wheel the drivers side control arm is about an inch away from tire and passenger side touches slightly at full turn. I have an adjustable track bar but I have the axle centered under Jeep????
