So its time to change the bushings out in my 06 TJ. The controls arms are not the adjustable ones. Can I take one control arm off at a time to replace them or leave one side on and do the other?. Will it need to be aligned?
you can take one off at a time or all of them off, doesn't matter. It will be easiest to take one off, replace the bushing and put it back on. you wont need an alignment.
I would do one at a time, you are mainly just removing 2 bolts, dropping the arm, replacing the bushing, reinstalling the arm= no alignment needed afterwards.
