Mybadjk
So I’ve been dealing with this for over six months. Engine has constantly been throwing codes.
Codes as listed:
Po394 camshaft sensor.
Po6dd no description
P2638 torque management feedback
C121c torque request signal denied
Others have been low oil pressure, throttle positioning, one regarding throttle response.
I have replaced camshaft and crank sensors, new plugs. From what I’ve read it’s been a common issue but haven’t seen anyone’s actual results. And if they did, none of them have been consistent. Have changed oil multiple times, thicker oil. Was in the process of switching to the newer 14’ oil housing hoping it would fix the issue/ possibly see if I’m loosing oil. But the valley only had a little but underneath. One oil change I was 3q low on 3200 mile oil change with royal purple.
So, my thoughts are the oil pump in the pan is gone, or last thing is the ring and pistons are done. Recently broke a broke off the new oil cooler housing and is stuck in the block.
Maybe it’s time for an ls with a stand alone run by wire . [emoji28]
Codes as listed:
