desertrunner
So I'm gonna throw this up to maybe confirm some of the research I did. On my 12' 2dr the other day at the store I shut it off and hopped out. As soon as I opened the door the horn started going off like I was holding my hand on it. Lasted about 1 min then stopped. Went to lock it with the key and again did the same thing. Started it back up it stopped but to test a theory I hit the hazards and it went off again. I tried the battery reset for 10 mins with no luck. Pulled the fuses for the horn to make it stop. Everything else seems to be working normal but every time I try to put the fuses back in the horn goes off. I don't have any lights on the dash either.
Based on what I read it's most likely 1 of 2 things. Clockspring or the cruise control switch (that one has me shaking my head but seems as common as the clockspring)
I do plan to just dealership fix this one but wanted to see if anyone else had the same issue and what fixed it?
I also heard jeep started a big extension to the clock spring warranty but does that apply if I'm not the original owner and have no factory warranty?
