bruggymonster
Does anyone run this CB? I was given it as a gift a couple years ago and want to put it in the Jeep. Can anyone show me how they mounted/ wired it? Or if anyone can direct me to a thread, that'd be nice too :thumb:
I switched to this unit and love it. I would recommend getting a small external speaker as it makes a world of difference. As far as mounting goes - Remove your glove box and you will see a metal support brace at the bottom - Just tie wrap it under there and you are good to go. A few companies make a mic holder that integrates with the passenger grab handle.
I've seen that mount and love the way it looks! Who sells it?
And does it ever get in the way of the passengers knees or anything like that?
Great CB as long as you are real careful to do the install with a quality antenna and have a good ground. You will want to get a SWR meter to tune your antenna. Right Channel Radio sells complete packages to get you set up without wasting money or damaging your equipment.
If you go to Right Channel Radio website you will actually find install guidelines for setting that radio up to get the best performance possible.
I had never touched a CB until just prior to a Jeep Jamboree we attended and a CB was required. Right Channel fixed us up and saved us a bunch of bucks. Instant crash course.
There is also a good U tube video of a fairly clean install of that very radio in a JKU. it shows running the coax cable through the roll bar cover from back door and then great place to run power from battery direct. Hope this helps, it certainly did us
EDIT: At Right Chanel Radio got to the "learning center" (its a selection you can make near the top right), then select Jeep. You may be surprised.
I am also seriously considering this CB. I have heard almost nothing but good reviews about it. On the subject of running an external speaker with it…is it that imperative? I have heard mixed reviews, some saying its fine without it but just might be a little hard to hear if your running doorless and stuff. But i have also heard people running it through an aux hookup and which runs through the factory sound system. Has anyone heard or done this?
Where would you get an SWR meter? Does Right Channel Radio sell one?
Paired up with a good antenna and good swr. About how far will this radio get out and receive ?
I plan on installing this CB in the very near future and was wondering what you guys would suggest for buying parts. Besides buying the radio itself and components that come with it, I assume some length of coax cable and what antenna would you recommend? I was thinking a 4'-5' firestik II with a tunable tip just wondering what your guys thoughts were and what materials I would need to get to install this. Thank you. :thumb:
I would also recommend an external speaker.
