Did you make sure to install the nylon washer with the step sitting inside the mounting hole?
Yes I did, I checked to make sure I had it as the diagram was showing.
Okay, so what kind of reading are you getting? Is it pegging out or is it just high?
It just fills the meter and gives me the warning on the screen. Im sure its well over 3
Okay, that helps. If you're not grounding out, it could be that you're just not getting a good enough ground off the tailgate. What kind of wire or strap are you using?
I cant remember the wire but I think its 12ga wire grounded to the tire carrier bolt. Is there a grounding strap you would recommend?
Yeah, maybe try going to Pepboys or the like and get a ground strap. It'll look like a braided ribbon of steel wire. Sand off any paint at the point where you attach it too also.
Did you run a ground wire from your tub to your tailgate?
No I just have one from the mount to the tire carrier bolt
I ran a ground wire from the tub to the tailgate. I followed the existing wires into the tailgate from a attachment point near the roll bar mount.
So if I ground the tailgate do you think that will be enough to get my CB grounded through the tire carrier bolt? If I use grounding straps
