If it squeaks when you push down on the pedal, you most likely have a clutch slave that is leaking and or is going bad. They're just plastic housings with a spring and they aren't known for being the most durable part in the world. Back when I still had a manual, I ended up going through 3 of them. If you're still under warranty, I would have your dealership replace it.
