Cluster on the fritz
Get a shop manual if you don't have one. Chilton's, Hanson's, etc.
Disconnect the battery and disconnect the connections of the pcm(right be hind the battery. Check for dirt, water, corrosion, melted wires/connections, etc.
Pull the driver side dash apart. Pull the dash module out and disconnect. Same thing. Check for dirt, corrosion, melted wires/connections.
Start there and let us know.
