I just left the house the other day when every warning light came on, started with sway bar light blinking then all the rest on my 2010 jku. Vehicle drives fine while its started but no Gauges except fuel, but when you shut it off and try to restart, it doesn't want to even turn over. Tried to hook it up to get codes but it wouldn't communicate with the reader. Disconnected battery and cleaned terminals and still no solution. I've read other people have had bad/ loose grounds, loose battery connections, Pcm/ecm issues, sway bar motors out. Does anyone have any experience with this issue?
