HardRockRubicon
I'm in the market for a winch on my Hardrock JKU and after all my research I'm stuck and unable to pull the trigger for fear of getting the wrong winch. My budget is around $650 so I have narrowed my it down to four choices. The Smittybilt X2O-10($549.99), X2O-12(649.99), Warn VR8-S($669.99) & VR10-S($769.99). I know the VR8 might be a little small but I don't anticipate using it very often and could utilize a snatch block to increase the pull power. The price point for the VR8-S and the X2O-12 are the same so this is where the title came from. So if you had these two as a choice would you opt for the low end Warn or the upper end Smittybilt? If you went with the Smittybilt would you go for the overkill of the 12 or save a $100 and go with the 10? If you chose the Warn would you go with the underpowered 8 or go over budget by $100 and get the 10? Does anyone have experience with any of these specific models?
