JK_Dave
I'll start with my current specs and then describe the problem I have.
Current specs:
'13 JKU lifted ~3.5"
Front Reel 1350 Double Cardan drive shaft
Front upper and lower control arms
Upgraded from 3.73 to 4.88 R&P gears
+4.4 deg caster on stock Rubicon D44 axle
2.5 deg angle measured from pinion yoke U joint when perpendicular to the ground
8 deg angle of driveshaft measured from the middle of the D/S body
Stock 32" tires
The problem:
Prior to my gear upgrade, all the specs above were the same and I had no vibration, even at highway speeds. Now, after the gear upgrade, I've got a mild vibration starting around 50mph and gets more noticeable at highway speeds. I have not had the D/S balanced because it's only been on the Jeep for 6 months and was brand new.
I called up Reel to get their thoughts and he agreed it sounded like I needed to adjust the angle, but couldn't tell me with any certainty how much. In fact, his suggestion was to talk to Mel or Drew since they install these all the time and seem to have success with them. Before I do that, I wanted to get some thoughts from others who are familiar with this.
My thought is that I need to attempt to straighten the angle between the shaft and the pinion yoke as much as possible, but I don't think I can add that much negative caster without encountering steering problems. Short of getting under there and adjusting the arms, test driving it and making further adjustments, can anyone give me their experience of a happy window I can shoot for? Does it sound like I'm taking the right approach here?
Current specs:
Stock 32" tires
The problem:
