To get a good ground you need to scratch off the paint if there is paint on the surface you are mounting to, otherwise it can be spotty at best.
Learned this many years ago when I installed some rear offroad lights. Drilled a self tapping screw through the body figuring the screw would conduct to the fresh cut steel... didnt work that well and had to grind off the paint / rust before I had a good connection.
