BillTheCat
My tale of woe.
I have a 2013 JKU with a 3.5" lift and 35” tires. I’ve been running a TrailDash v1 but I decided to ditch it because it was not used much and my front/rear lockers would not work properly via the TrailDash. I reset the ECU first with the TrailDash then with an AEV ProCal. I turned off the “Sway Bar” warning because I have a manual disconnect. Good: Light is out.
Next, I reset the axle ratio to 5.13 (an upgrade about 18 months ago). Next, I set the tire size to 34”. Last, I reset the DTC codes. All is well on the test drive until I stop and start again ... Check Engine light.
My baby cannot get into 4th or 5th gear. First through 3rd is good.
Take the beast to my favorite shop. He hooks up his computer and gets “P0734”. He suggests I go the dealership. Went to setup an appointment to discover my drive warranty is expired in August of this year. Lucky me.
Bought a BAFX Blluetooth OBDII Scan Tool and verified.
Vehicle VIN:
Vehicle Manufacturer: Chrysler
Vehicle Calibration ID: Not present
Current Fault Log
ECU reports no current faults
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
P0734: Gear 4 Incorrect Ratio
End of report.
Before I give the dealership all my next upgrade $$$$, I’d thought I’d ask around first.
Thanks!
Vehicle VIN:
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
Thanks!
