silverbackjk
I have a genright aluminum tire carrier and want to cut the latch brackets off and weld them to the EVO rear skins. Will this work?
No it won't work
Found these photos on a welding forum it just brakes apart once you weld it.
You can bolt an aluminum plate to steel, you still risk bi-metalic corrosion. But then you are free to weld aluminum to aluminum.
