Cam washers from the factory?
GuahanJeeper671
I have 2 square cam looking washers on my front LCA’s I was wondering if that’s from the factory or aftermarket? Bought the jeep second hand so not quite sure
Aftermarket and not the recommended way to go. You can also see you have aftermarket geometry correction brackets on the frame side.
Yes I installed the correction brackets myself but thanks will be taking those off when I get off I’m sitting at 7.5 degrees measuring off the driveshaft thought that would be the reason as to why I’m getting that much
