Cam Bolt question
GuahanJeeper671
I have a 2.5 rubicon express lift kit with Barnes 4WD drop brackets and stock control arms I was wondering would cam bolts help more with the geometry and if so which one is best recommended?
Please do yourself a favor and NOT install cam bolts. Doing so will require you to change the square bolt holes in your control arm mounts into rectangular slots and that will lead to problems that you can only fix with a welder. The drop brackets alone should help correct suspension geometry and if for whatever reason you feeling a need to add in a bit more positive caster, do it with adjustable control arms.
