So My 15 JKUR recently started making a chugga chugga noise in the drivetrain. This has been a bitch to track down. Inspecting, I found the front DS seal finally gave way after 41k miles. I pulled it off to troubleshoot and will replace. Noise is still there. The rear DS seal is still intact, so I suspected the rear wheel bearings after feeling movement on one side. Replaced the stocks with new, pressed 10 factory axle shafts. Been meaning to upgrade those for awhile. Noise is still there. Checked for movement on the pinion in case the bearings failed. Zero movements. Opened the diff, all looks well.
So now it's down to the rear DS. The noise is only evident during deceleration around 17 mph. Put the trans into N, still there. Present on braking, and e-braking. Put the transfer case into N AND IT STOPS.
This exercise is starting to get expensive. Pulled out the gopro and made the following video.
Please share your thoughts on what this may be. I'm suspecting the DS, but I can't track the damn noise down.
https://www.youtube.com/watch?time_continue=183&v=oA9z8BMjIOY
