Does any one know if the rear parking sensors can be disabled. I plan on going bumperless in the rear but held up by the sensor dilemma. Any suggestions would be appreciated
Can you jump the plug ends to trick the ECU, or putting sensors on the body?
They’re probably inductive prox detectors, in which case those are normally open.
Just cut ‘em off. If they’re normally open tape off the wires separate. If they’re normally closed splice them together. Are they two or three wire?
I would suspect they are 3 wire, also probably not able to jump. If it is a induction loop, you cant jump that.
After posting and thinking about it, my guess is the factory probably put in a fail safe, considering these devices are to prevent stupid people from running over their kids. Im glad my 18 doesn't have them.
Interesting thread btw.
