dlm_jku
Since upgrading to 37s, at full stuff I have some rubbing in the rear. I was thinking about just trimming my bumper back as bit (around where the red line I drew is), and cut the corner of the pinch-seam off. I'm assuming this will be pretty trivial, but since this will be very visible and I haven't done much like this before, I thought I'd ask for advice.
I'm thinking I'd tape off the area to cut, draw a line, and use an angle grinder w/ cutoff wheel to make my cut. Same for the pinch seam, then use some JB-weld or something similar to seal the seam. For the bumper I was thinking after cutting I'd use a hand file and/or grinding disk to smooth out the edge, then seal it with some spray paint.
Any tips/suggestions to this process for better results?
