Captain Ed
So I had a mechanic that works on the side (hes a Jeep Mechanic during the day) build my D44 non rubi stock axle. He added an ARB Air locker and used Tenfactory chromoly 35 spline shafts. I drive the thing around and find no leak but I am still in the intel phase because I got a significant leak out of the drivers side when I engaged the rear locker. Is this possible or am I just thinking the locker can cause a leak. On the same note he put a Metalcloak adjustable rear track bar on but he used the stock mounting hole. I have a 2.5 teraflex spring lift for now but it did have the rear track bar bracket from Teraflex. He said since I am using an adjustable track bar I don't need the bracket but I have seen them recommended by both TF and Metalcloak. Its leaking on the drivers side more so when the locker is on I think. I only put about 30 miles on it so far because I'm scared its going to run out of fluid but I checked it today and its fine.
So I need some intel on 35 spline axle seals,
I need intel on ARB air lockers
I need intel on rear track bar correction brackets.
I should have just went with the D60 rear, my front Dyantrac Pro rock 44 is solid so far. Jeeps!!!!!
Thanks guys and girls.
