Brocken air blender door pass side
frenchjk
Hi all,
Does anybody know if the Air blender door in the heating/AC system on the passenger side is changeable. The part that holds it to the actuator motor's axle on mine is broken in 4 different pieces. Guess the plastic is not really up to par (must be chinese with crappy QC)?
Thanks
Hi all,
Thanks
Yes the part is replaceable. And is alot easier to replace then the driver side.
Mine is broken right here
If you want to replace only the door itself, you can’t. You have to pull your entire dashboard out and replace this whole piece
If it’s only actuator that’s is not working, yes you can change it and it’s a real pain in the ass. You need to remove the speaker and try to squeeze you hands back there. A little stubby screw driver helps a lot.
dealership fault.
Shiat........I'll let the dealer do that, it's in part their fault anyways because they messed up the cabin filter install by cutting the filter in two (not the right ref, there are two in Mopars catalog, should have done it myself but, hey, they had the JK in for oil etc)..and the thing went flying into the ventilator and messed up the whole area...:mad:
Guess I'll be driving a renegade for a day or two when thay get the parts.:blush:
