Colorado4x4
Check this out. I thought this noise was coming from my front end. I removed the front stock driveshaft (rzeppa boot torn) because I thought the driveshaft was making the noise. Nope. I found that it is coming from the rear driver side thanks to the GoPro. When I am in a turn and the weight of the Jeep goes to the driver side the noise is pretty loud. The noise completely stops when I press the brake pedal in. 2016 JKU with 59,000 miles. I put new pads and rotors on maybe 8,000 miles ago. I just installed new chromoly rear shafts and the noise was there before and still there after. Looks like I’m going to pull it all apart again. Maybe something is caught up in there but the oscillating sound makes me think the rotor is uneven? Or the caliper slider pins are stuck or I need new calipers because they’re not retracting? Any tips? Thanks.
https://youtu.be/i2BGGlmo_eQ
I’m driving around the roundabout and people thought I was crazy.
