whitee27
Now this is a little hard to explain but something happened recently and all my bluetooth calls are staticky for the first 30 to 60 seconds of driving. I have tried with 2 different phones with the same issue. It seems after some time it will stop being fuzzy and work correctly. I can't make or receive any calls as it is very staticky. If I use my phone normal without going through the vehicle (bluetooth) it works fine. I can also stream music without any issue but can't make a clear call.
I have a 2017 JK with the 430N deck. Any help or guidance would be appreciated. I also don't have much knowledge in regards to electrical so troubleshooting is tough. Could it be my antenna? I did put on an aftermarket stubby and swapped it back with the factory and that didn't help. I'm not sure if bluetooth uses the antenna any how?
Thanks in advance.
Thanks in advance.
