mickeydarmi
The fluid in my brake/clutch system is old and has absorbed a little too much moisture. I’m starting to notice it on the clutch side more than the brake side, so my question is this — I’m assuming that to be sure all the old fluid is replaced with new DOT3, I need to not only bleed the clutch system at the slave cylinder, but also bleed the brakes at all 4 wheel calipers since the fluid is shared. Can anyone confirm? I’d really like to just do the clutch, but I’m worried that won’t solve the issue ...
