Bilstien stabilizer fixed my radial pull
2trackin
So I had been having some pulling to the right on my 37" Toyo equipped 2014 JKR. Alignment was within spec and still had some pull to the right. Not to much, but enough to be annoying especially on very rough roads as I was constantly holding left and hitting bumps at the same time definitely caused some white knuckles.
For the heck of it I threw on a bilstien gas charged stabilizer. This gives a little push due to the gas charged. And believe it on not the same roads tested just before the install and pulled right now drive perfectly straight. I'm very happy with the outcome of this.
On a side note, like I said I had an alignment done putting things in spec.
I had rotated tires around and played with pressures as well. I run 25psi up front and 24 in the rear.
I don't know if this is a true fix for radial pull. But it sure worked for me.
Also it drove straight all the way up to 80mph (highest speed I went).
Just thought I'd offer another approach for others experiencing the same issue.
I'm glad this worked for you. I ran 37" Toyos on my 2008 for close to 50,000 miles and never had any noticeable radial pull. Every vehicle is different.
