Ddays
Ok, so this may not be the most hi-tech post ever, but this is the best method I've found to mount stickers that are straight, level and without defects. There's nothing worse than putting a sticker on and then stepping back and seeing the damn thing is not straight. Or getting halfway done and seeing a big ugly wrinkle in it. This method works on paint as well as windows. In fact, if you've ever installed tinted window film, you already know how to do this;
Requirements:
Cool sticker (Sorry Eddie, not ready to put my WAL stickers on yet - had to use a stand-in)
Any window cleaner but make sure that it doesn't contain Ammonia! Plain white vinegar will work. Soapy water works great too, especially for very large stickers.
bondo squeege
Wax paper
Tape measure
Adult beverage of your choice optional
First clean surface and then spray surface area liberally with the window cleaner
I've found that the window cleaner works best because it has high surface tension and doesn't just run off the surface.
Remove sticker backing and spray the back of the sticker liberally as well. Don't hold back here. Make sure that both surfaces are thoroughly soaked!
Apply sticker to surface. Make sure sticker slides around a little. Now's the time to either line it up with a body line or crease, or if in an open area break out a level. Especially if the sticker is large. Take the time to measure the placement and/or center the sticker now. After the next step it becomes harder to do so.
Place sheet of wax paper over sticker and press it by hand so that it covers it completely. Smooth over with your hand making sure that you don't move it.
Hold wax paper from one end and pressing down on decal holding it firmly in place. Wipe squeege from middle of sticker out. Be careful around sharp edges and points - make sure that you squeege outwards and not inwards over those.
Last step; take sip of adult beverage and admire handiwork!
After a day or so (or a couple hours in direct sunlight) the last of the window cleaner left after squeegeeing will evaporate and the sticker will be stuck good.
Hopefully someone out there can save themself some grief with this post.
Requirements:
bondo squeege
Wax paper
Tape measure
