CapnMericaMyCopilot
So this morning tried to leave for work and I couldn't even unlock the doors. Got in manually and tried to start it up and I got nothing... didn't try to turn over, no clicks, nothing. I'm presuming/hoping this this is battery related but seems weird that it literally happened overnight? In the last month the only changes have been wiring CB radio, installing heavy duty battery terminals, replacing headlight harness that had a bad relay, and OBD scanner. Figure I'll stop by Autozone on my way home and have them test it but curious as to what may have happened or if its even actually the battery. I should mention its still the factory battery and just hit two years
I've had the following happen:
Noticed this past weekend that my clock had reset and the compass was up instead of the speedo.
Yesterday evening unlocked fine, had lights, auxiliary power, radio, etc. but didn't start first turn. Second turn no problem started right up. I honestly thought I just didn't turn the key enough because it was so quick but the girlfriend asked what was wrong with the battery.
This morning, like I said, I couldn't even unlock the doors... had absolutely nothing, almost as though the battery was disconnected. The only response I could get was if I tried remote start I would get one honk but not the second for the engine starting. Since trying to lock/unlock from the FOB didn't work, I manually unlocked the driver side, but when I manually unlocked the passenger side to get my 10mm for the battery, I had the alarm go off. Engine didn't even try to turn and nothing on the dash lit up. Called someone for a jump and figured I may as well try again after confirming everything was secure and connected well and it started right up with no struggle after a few turns of the key (there was no trying to start it went right from nothing to ready to go).
