Axles
jdofmemi
Will JK axles fit a JL?
No particular reason to ask this, yet anyway, just curious.
Particularly aftermarket axles, but with the JK mounts.
Yeah, should bolt up but the JK axles will be narrower by a bit. Lower control arm bolts will be a bit smaller too.
Thanks.
Just a wild notion on my 68.5" Fusion 60s.
There might be something different with the tone rings. The brackets are similar, but I think the rings had a different tooth pattern. Dan from fusion explained it to me before I sold them to you, but I would check with him.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Thanks.
Oh yeah, they'll bolt right up.
Do Fusion axles require you use different speed sensors? If you're still using OE sensors, you should be fine using them on a JL. ProRock 60 and 80 axles use different tone rings too but they still work.
