Bonechief121
Backstory: 2007 JKUR
Stock axle right side leaking pull it apart sleeve axle, C’s and new Synergy inner seals. Axle still leaks.
Pull it apart and put new Mopar seals in and it still leaks from the right side.
Bought a new Teraflex housing with seals already installed. Still leaks from the right side.
I have used stock amount of fluid still leaks, filled to the low pinion drain on the Teraflex cover and it still leaks.
Could an axle shaft cause a leak? The shafts are Superior Alloys.
