Axle seal leak
Ben-0
My front axle seal is leaking and needs to be replaced, iv changed these in different differentials before mostly fords 8.8 and 9 no Dana's and I know there is a difference. Iv searched for write ups in a couple different forums and found nothing so far. I was wondering what are a good brand of seal to get and maybe point me in the right direction as far as a write or something.
Thanks guys
from what ive heard you have to gut the housing to get to them (pull the shafts and the diff out) it doesnt sound fun at all, unless some cool upgrades are going in at the same time!
It's a piece of cake man. Yes you have to remove everything. Brakes, axle shafts, and the carrier. As mentioned above you gut the housing. Then swapping out the seals is easy. Then you just re-install everything you removed. Good luck.
