UNLIMITED_FUN
Increasingly I can;t move the shifter out of reverse.
When I finally CAN, then I can switch to other gears just fine.
Put it back in Park, maybe I can, maybe I can't. There seems to be no rhyme or reason for the ability to change gears.
After trying, prying, swearing, eventually it just suddenly slides in to reverse as if nothing had ever happened.
Once I get it to reverse or drive, I can hear a slight actuator sound.
I thought there might be a problem with a switch behind the brake pedal, but guess what . . . I can change to reverse without depressing the brake at all.
I've read a few forums and threads about plastic shafts in the handle etc, folks using zip ties or chopsticks.
I'll crawl underneath and have a look, but in the mean time, anyone have any other ideas?
The transmission fluid was just at the safe line so I added 1\2 quart, it's clean looking.
Also this transmission was put in last fall with an alleged 3yr 36k warranty.
Thanks for your suggestions!
