ATX Slabs and a ProRock 60?
LarryG
ATX Slabs and a ProRock 60? EDIT, Houston, we have a problem
I was about to pull the trigger on my wheels, but as I am going with the ProRock 60 front and rear....
EDIT: My choice of wheels "was" the ATX Slabs, but.....not a single place here locally will touch them. I can certainly mount the tires to the wheels, but no one will spin balance the set.
How are others getting this done?
I was about to pull the trigger on my wheels, but as I am going with the ProRock 60 front and rear....I was advised by Dynatrac that the 5 on 5 bolt pattern won't work....so I am trying to find ATX Slabs with the 5 on 5.5.....cant. Any suggestions on this?
Why not go 8-lug?
Agreed ^^^
If you haven't got your axles yet and you're needing new wheels, I would definitely go with 8 lug. Much better way to go.
Here is an 18" one with that wheel pattern.
https://www.amazon.com/gp/aw/d/B00V...SX236_SY340_QL65&keywords=atx+slab+17x9+5x5.5
Check out off road evolutions webpage. They sell slabs and should have that bolt pattern.
Them next best bet is to call ATX/KMC directly if Google isn't helping you.
10k per axle not including new wheels drive shafts and other little stuff that adds up at least 25k
I have quotes for XD60s, in semi and full float. None of them over $17k. Obviously depends on options and full or semi but "10k per axle" is not entirely accurate.
I'm sorry I was referring to the front xd60 and my rear pr80 full float each are roughly about 10k but yes with a rear semi float would be cheaper in price on a 60 I'm sorry I stand corrected
Where do you comeup with that cost..even my PR60-80 with upgrades delivered didn't cost $20k
It's easy. Add in expensive options like RCV shafts and it's doable. I think it was about 15k ish for the front if yo choose every option on the quite sheet. Not 25k when you add in the PR80 cost but close.
