ended up throwing it away only because i had to cut and grind the truss "alot" to fit my axle. if its stock axle or not done any work done to it, it would work well. also built well when i saw it in real person. id recommand spraying paint except weling spots before you weld it on.
From what I hear, it is very hard to weld a truss on to an axle without warping the housing even if you have all of the proper equipment. Save your money
The kit for the 44 is great. We installed the entire kit with no grinding of the armor material. We took our time and we stopped and checked the heat as we went and it came out great.
The kit comes with truss, gussets, control arm skids, swaybar relocation tabs, and HD tracbar bracket.
