kbsvo2go
I recently had a friend of mine give me a ARB CKMA12 compressor. When it was installed in his Jeep it was only used to air up tires and that was my plan for it as well. I have a 2012 Sport so I made a bracket and mounted it right over the ABS unit on the driver side of the engine bay. My trouble occurs when I go to air up my tires the unit will trip the thermal overload sometime during the 4th tire. I'm only airing up from 12-26psi and it takes about 2.5 minutes each. The first time it did it I had the hood closed so I tried again yesterday with the hood open and had the same result. The ambient temps are in the mid 80's. Is this just a matter of too much heat under the hood or could the hand me down compressor be failing?
