OverlanderJK said:Most likely you need to make your posts longer or just use the quote option. If I don't have two lines on mine it won't let me send it. An easy way to fix that is to just use the quote option.
There does seem to be an issue with the Wayalife app. Buttons seem to loose functionality.
Do you mean when you post? If I recall after the update you have to hit return before sending a post.
Hitting return before posting works for me also.
OverlanderJK said:Yes, on my iPad I need to have at least two lines. Hitting return will fix that but there is a problem with the app that Eddie said is being addressed by the programers. The right side of the screen seems to not work. Again that is on my iPad. iPhone works great though!
OverlanderJK said:When was your last update? Mine was December 7th and that is when I started to have the issues. I see no update now.
That was the last update and we were pleading with Internet Brands to do this because it was needed badly. Last year they bought the company that released the apps originally. It is up to them to work with the app developer and keep it current.
There is any easy fix...rotate your mobile device 90* in either direction.
There is an easy fix...rotate your mobile device 90* in either direction.
