These are actually pretty bright, a friend got some pretty cheap at the expo and mounted them between the frame and his evo sliders. I'll see if he has a good pic
He wanted the platinums for light in front of the axle. The anzo's put out enough to not need anything else for the rear axle.
Originally he was going to use 2 per front wheel well and 1 per rear, but couldn't get them to work individually when he cut the strand. After the first light it's a 3 wire setup. According to the anzo rep, if one is damaged the others continue to work, but from what my friend found was once u remove the first one, the others won't work. I wasn't there when he was fooling around with them, so can't give any more specifics or say it wasn't user error.
