lesterjanpearson
anyone running 35x12.50 and 20x12 on a budget lift kit/spacers?
or is it possible? only a daily driver for a Sport 2016.
I would avoid a 12" wheel withdraw a 12.5" tire. You will not be able to air down significantly with that setup. I wouldn't go larger than an 18" - 9" with that tire.
He may not want to air down tho. Could just be doing it for looks
True. If you are not going offroad, this setup will work. If you actually want to use your jeep, pass on this setup.
Most I could do here is are simple trails, no rock crawling, just rocky roads, I doubt there will be flexing.
And I am going more for the looks for now. but shops here says I need 4" lift. but I am on budget.
I've been on a 2.5" budget boost with 35s for over a year now. Fuck that shop, you'll be fine
Sure thing. These are the most recent ones.
And here is one while off road. I do rub the on the front fenders but only because I have 2" bump stops and not 2.5".
You will be absolutely fine. Here is my evo 1.5" leveling kit with 35s.
Ran fine on the road without cut flares. Will definitely have to cut flares if you flex it out.
I know you said you wanted a budget lift, this is my way of showing you you will be more then fine. Never go back to that shop. They will charge you an arm and a leg for something that can be done in your driveway in just a few hours. Putting my lift kit on myself and actually LEARNING my jeep was the best thing ive ever done. No more wasted money in the shop and much more comfortable knowing i know how to fix 8 of the 10 problems i could potentially run into
Ahh, I sure do miss my EVO level.
Seriously man! For what this little kit is, i love it! Bought it a second time when i got a new jeep
You're running it on your 2dr as well? Been considering it again for my new one. Just because you can run stock tires with it, or you can run 35s. It looks and performs good either way!
