Indefatigable said:I hate the RE bushings and joints with a passion.
That is all.
Re changes the bushings on the kits recently. Not saying you still won't have issues with a radius...
if you're just planning to run hard and fast out in the desert, it'll work great. if you're looking to play on the rocks and want big flex, you might want to see if you can cancel your order. while you can force radius arms to flex, it will come at the price of blown out bushings. more times than not, they will blow out in just one run - trust me, i have seen this time and time again. for big flex, you really should look at getting a 4-link long arm kit.
So what 4 link do you suggest?
highoctane said:I have a friend who replaced the bushings in his 4.5" RE long arm with the daystar replacement bushings just under a year ago. Those are a much stronger bushing and they are worn out and clunking.
I have RE long arm and have for 3 years, although I did have bushings replaced once the kit performs great!
Ended up getting rancho short arm very satisfied
