Lss Broly jku
I Plan on taking the jk out to pismo beach this weekend just seeking any tips to avoid getting stuck. Thanks in advance
Running a 2.5 lift 33’s
6-8 might be pushing it without beadlocks. I’m sure it could be done, but it would make me nervous. I definitely agree though, air down for the bigger footprint and stay in gears that allow you to keep the tires moving.
Going off of what Brute and Sharkey said. Air down as low as you can without losing the bead. In the Jeep 10-12 without bead locks shouldn't be a problem. You can go lower but don't turn sharp.
Use large wide sweeping turns. Momentum is your friend. If you start to spin and dig in stop right away. A lot of times if your getting stuck a couple people pushing is all it takes to get you back up on top of the sand and moving.
Not 4x4 low. You can't get the momentum you needUnder 10psi , low 4x4, bring a yank strap. You’ll be fine and have fun. Air down til your tires squat wide. Sharp turns not smart will push tires off bead.
Roger that...the biggest part is if you lose traction or flotation, stop before you dig down to the framerails...
Maybe with a Sport, but the Rubi low wouldn't be a good idea.That’s what the skinny pedal is for... I never touch high when I’m out in the dunes.
