If you own a Rubicon, why would you need to buy discos? Its electronic on a Rubicon.
You mean selecting the correct length to prevent your links from being inverted?
These are not discos. Sorry, I should have said I have a RK 2.5" lift. Looking for a solution for the potential sway bar flip.
Actually the pic you provided are quick discos.......... If you own a rubicon you best bet is to just get some fixed length links or some slightly adjustable links. Set your sway bar about 15* above parallel and measure eye to eye.
Most 2.5" kits can use factory rears in the front. If those are the correct length then they should work fine.
Actually they aren't the quick discos. There are no pins to pull out if you look closer. Took it right from their site.
I guess the exact same set I use to run wasn't a quick disco then. I will let you be and go back to being a web wheeler
I have the RK links that came with my kit. They are not long enough.
I just wanted to know if anybody had any experience with these particular adjustable sway bar links.
They are the exact same as the "quick discos" but come without the pins that replace the bolts. So anyone who has had the quick discos has had experience with them..... And speaking from that experience they are fine.
Yes they will work with your Rubicon E-Disco.
Fuck that I'M the Web Wheeler here! Don't steal my thunder Stephan.
