Any ideas on how to wire a cell phone charger into the Jeep permanently?
GraniteCrystal
All right, this might be a little out there, but go with me for a minute...
I have an old cell phone (Samsung S4) that I no longer use but I think might still be able to be used as an altimeter. I downloaded several apps today that all seem to be working and claim to work even without a data connection. The idea would be to permanently mount the cell phone to the dash and have an always-on elevation displaying on the screen. Then as I crawl around the mountains of Colorado, I can always know my elevation.
I'd prefer that:
a) the cell phone not need to be removed from the Jeep to be charged indoors
b) not take up my cigarette lighter or other electrical outlets
c) not show any cords
Ideally I'm hoping to glue a mount to the dash which has a cord running out of it and under the dash and...then I'm not sure. Is there another power source behind the UConnect 430 I could tap into? Use battery power somehow?
Any ideas appreciated.
Thanks!
Christrap did a solid write up on installing some USB ports into the dash.
http://wayalife.com/showthread.php?t=18140
In dash USB plugs
My only concern with permanently mounting anything like that is the current speed to which these devices are becoming obsolete. Now not only are you dealing with the device, but with proprietary designs of plugs. I have a long history with installs in all types of vehicles. I have found that keeping it simple is the best way to not have to fix a hole in the dash.
I did an isimple 32 (I think that's the model). It can do USB or headphone jack and comes with a module so you can run an mp3 player through your factory system. It's about 50 bucks. Here's a pic of how I installed mine with the provided mount:
You can easily hide the wires better than I did. However, you can mount the button and both plugs anywhere else too. You don't have to use the provided mount. Here's a quick google image search:
https://www.google.com/search?q=isi...34Q_AUICCgD#tbm=isch&q=isimple+is32+installed
In dash USB plugs
Thanks for the link! Agreed on speed of tech but USB doesn't seem to be going anywhere fast
Looks like the wires disappear into your dash. Going to cigarette lighter?
Yes sir
On the right side of the Nav screen should be displayed Elev. , Speed, and posted speed. Seems to me there is something else as well.
When I was a teenager my Dad gave me a altimiter from an aircraft he was working on.
Had it mounted in the dash of my 72 GT for years.
Sold the car with it in there.
Home from work today with fresh hand surgery so could take a photo of my 430N in Nav mode if it would help you.
I also have my Galaxy S4 mounted next to my CB on a overhead mount.
Dont text though.
Good luck
They go under the console. The kit comes with 2 wires if I remember right. A ground and a 12v. I think I hooked mine to 12v ignition from the radio. Basically any time the key is on, I will have power at the USB.
Yes sir
Dont text though.
Good luck
Well shoot. OK, I'll check it out later and let you know what I find. Thanks for the heads up.
Yes sir
Dont text though.
Good luck
I looked at my nav and I don't see it. Would you mind taking a picture of yours showing the elevation?
Okay here you go.
Checked it several times for accuracy and its within 20 feet. Alright for a Jeep, for an aircraft coming in to land not as much.
I went through the settings to see if there was a switch to toggle Elev. on and off but did not find one.
How to enable elevation/altimeter in Jeep
Okay here you go.
Ok, I got it working. Turns out it is a setting. Here is a walk through of how to enable this on the 430n nav system in a 2014 Jeep Wrangler Unlimited Rubicon (I'm sure it works the same way for most if not all JK models with the 430n).
From main navigation screen, select "Settings" in the lower right:
Select "Map" in the lower left":
Select "Map Data Layout" from the list of options:
Select "More data" from the list of options:
Save that setting and now when you view the map you should see something like this:
There are some other cool options in there as well. In the last image above, you can see I changed my icon to a Jeep instead of a blue arrow on the map.
Big thanks to everyone who replied! I still might run an extra power input in the future, in which case the other info provided will be very handy.
Good deal. Glad you were able to get it to work.
I ran a small usb from inside the consul power port that is always on up to the rearview area so I can charge or run on my GoPro.
There is even a little cut out in the side of the consol so as to not pinch the wire.
Then just snake it under consol,up under dash, then up the A pillar trim and along the windshild trim.
Truck stops have all kinds of made up usb's both mini and micro.
