JKJody
So being that my jeep is mostly built already, it's really not going to be that great of a build thread. I will dig up some old pics and post them up starting from when I took it home from the dealer. I guess I'm starting this because the jeep is beginning stage two of its life. Heres a list of all of my parts.
New jk build
2014 Anvil wrangler sport unlimited*
37" nitto trail grapplers*
Pro comp 7089 17x9*
Warn VR 10000 winch*
Factor 55 pro link*
EVO front bumper*
EVO front D ring mounts*
EVO rock rails*
EVO skid plate system*
EVO rockstars*
EVO sway bar disconnect*
EVO vacuum pump relocate*
Nemesis evap relocation*
Flow-master exhaust*
Poly front 4.5" springs*
Poly front track bar bracket*
Poly front track bar*
Poly front 3" bump stops*
Poly front shock relocation brackets*
Poly front axle sleeves*
Poly front C gussets*
Poly front control arm skids*
Poly drag link*
Poly tie rod*
Poly rear 3" springs*
Poly rear track bar bracket*
Poly rear track bar*
Poly rear bump stops*
Poly rear sway bar extensions
Crown brake lines*
Metal cloak control arms*
Airaid cold air intake*
AEV pro-cal*
AEV tire carrier*
AEV fuel caddy*
AEV rear corners*
Genright rear bumper
Genright license plate mount*
Genright 3rd brake light
Truck lite headlights*
Truck lite anti flicker harness*
Poison Spyder wheel spacers*
Poison Spyder cross member*
Rubicon sway bar*
JKS front sway bar links*
JKS rear sway bar links*
Fox IPF 2.0 shocks*
Fox ATS SS*
Reid racing knuckles*
Dynatrac diff cover D30*
Dynatrac diff cover D44*
Coast front 1310 drive shaft*
Coast rear 1310 drive shaft*
G2 4:88 ring/pinion. D30*
G2 4:88 ring/pinion. D44*
G2 master install kit D30*
G2 master install kit D44*
Teraflex big brake kit
ARB rear locker
Cobra 75 CB*
Icom SP35 speaker*
SPOD
Rigid 20" led light bar
Rigid D2 lights
Led interior lights*
(All of the "*" are the parts I have or are on the way).
This was an awesome day!
First thing is first....Trucklite leds!
New jk build
Pro comp 7089 17x9*
Factor 55 pro link*
EVO front bumper*
EVO rock rails*
EVO rockstars*
Poly drag link*
Poly tie rod*
Crown brake lines*
AEV pro-cal*
AEV tire carrier*
AEV fuel caddy*
AEV rear corners*
Rubicon sway bar*
Fox IPF 2.0 shocks*
Fox ATS SS*
ARB rear locker
Cobra 75 CB*
Icom SP35 speaker*
SPOD
Rigid D2 lights
