Jeep Bro 08
Is this ok to add to my overflow tank ?it doesn't say weather it hoat or oat
Sent from my SM-G900P using WAYALIFE mobile app
Guess its specific for jeep depending on which one is needed
This is the one i read .antifreeze at stores dont say if they are hoat,which is the one i need i believe
Think ur right bud ,had to ask before i use that stuff,my tank is completely emptyI would just go with mopar stuff to be safe. You can get some on amazon or straight from the dealer.
The link provided by another member is very helpful. I've referenced it many times. I will assume the OPs Jeep is an 08 based on your name?This is the one i read .antifreeze at stores dont say if they are hoat,which is the one i need i believe
Yes i got an 08, just got a jug from dealership my cap is black & its 5yr 100k miles . It was even cheaper there than autozoneThe link provided by another member is very helpful. I've referenced it many times. I will assume the OPs Jeep is an 08 based on your name?
My 08 I added HOAT it has a pinky color to it. My 16 which belive it or not I just topped up this week is OAT, and has a purple color to it. Careful the light can skew the color....weird.
The jug I purchased thus week from MOPAR when you read the small print on the back referenced OAT. The parts guys at my dealer is really on the ball, we double confirmed .
Do not mix or add the incorrect Coolant!!
Yes you can add directly to the overflow bottle as per your owners manual.
I agree with you MOPAR does not make it screaming obvious on the jug which flavor it is.....the cap color is helpful.
Jellymon has posted the picture of the correct color coolant for on 08. You should be good to go.Yes i got an 08, just got a jug from dealership my cap is black & its 5yr 100k miles . It was even cheaper there than autozone
